Error 8097: Controller Error - Configuration is not valid [0x05][0xE7]
azulaski
Apr 2022
Houston
Hello,
I am having an issue downloading to a GE 90-30, CPU 364, I have configured the EGD following a documentation on GE Ethernet Global Data Driver Help. I updated the CPU firmware to 10.75 and I keep getting an error and code would not download. Can someone tell me what I could be doing wrong?
Error occurs right at Downloading: ETHERNET GLOBAL
I have attached the code for reference, thank you very much.
Error 8097: Controller Error - CPU slot mismatch [0x05][0x46] [0xC00C0001] I got that error above when I was trying to download my programming to...
424
One of our customers had a Rx7i redundant Controller system for their plant. Due to some power failure the Controllers power was interrupted. Now...
4,456
I’m getting this error: I’ve pulled the battery and left it out for a few minutes. It’s been a while since I’ve ran into this and I can’t...
976
I am trying to download a program that will only change the integrated IP address in a rx3i IC695CPE305. The logic is equal. The current IP is...
5,495
Hello everyone I have the next issue with FactoryTalk Linx, when i configure the Ethernet driver and try to find the IP Address of the PLC Device...
41
