Rx7i Controller error 8097
adnan_hayat88
Apr 2013
Karachi
46
One of our customers had a Rx7i redundant Controller system for their plant. Due to some power failure the Controllers power was interrupted. Now the plant is running on Secondary PLC. I am trying to connect to the Primary Controller Ic698CRE020 but it is not replying to its IP. I was able to connect to the Controller using Com port. But when I download the logic at the very end of the process it shows an error:
Error 8097: Controller Error- Controller aborted the request [0x05] [0xFF] [0x803B001E] . Kindly help me out.
You will likely find the answer in this file, but without being there or knowing a LOT more about what you see I can not tell you which it is. BTW, this is from PME 8.0 online help.
Hi All, I have a question would like to ask the experts: my system has two Rx7i PLCs and I'm having them communicate with an RTU (D25) via modbus...
2,072
I have an Rx7i that is dropping out randomly. The modules and rack have been replaced. The CRM is on one of the I/O modules (rack 1 slot 6) so...
1,582
I have a RX7i application that I would like to "convert" (or, perhaps <port> is a better word) to ...well, something else. The code is Proficy ME...
2,634
I need to design an Rx7i based system in which 14 PLC`s will be communicating with a redundant HMI server. Each PLC should also be redundant(HSB...
1,495
I have an Rx7i Redundant Controller having a Single Genius Bus Network i.e Each Primary and Secondary rack have one GBC. This has happened three...
2,236
