AB DH+ connector
gautham
Guest
G
I am looking for Allen Bradley DH+ connector (3 pin connector) (1,sh,2) for connecting my PLCs in a network. What is Allen bradley part no. for this 3 pin connector.
I found in one of the connector with the below details:
Make: phoenix contact
Part no.: MSTB2.5
Description: Removable wire connect plug
But when i contacted phoenix contact they said they donot have this part no. anymore.
I need 50 nos. of this connector.
Your suggestion needed
thanks
DH+ connector
Dear Mr.Kim gold and Shahn4
I found out part no.: 22112-046-03 in ab website at the mentioned Panelview manual.
I also searched the price for this connector in AB shop-online website and found the price to be USD 14.40. which is quite expensive.
SO i went on to search for the Phoenix contact part no. but the website could not recognise the phoenix order no.(article no.) 1849396
also i could not find AB Part no. 941999-03
Below is what i searched in AB Knowledgebase Doc. ID:9996 "Programmable controller piece parts"
TERMINAL CONNECTORS:
Part no.: 940611-03
3 position 1785-LT, LT2, LT3, LT4, L40B/L, L60B/L 1771-AM1, AM2 remote I/O connector ,1775-S5/SR5
Part no.: 940874-01
Female section of terminal connector 3 pos
But could not find the price for them in AB website.
Can you please let me know the part for phoenix contact 3 position connector for DH+/RIO.
Many thanks again
Thanks Kim gold. You are correct. I saw those part no. in PKTX manual after reading your post. But could not find this part no. in Phoenix website. www.phoenixcon.com.
Is there any other source from where i can buy this connector for good price.
Many thanks again
I guess these connectors must be stocked under a variety of numbers. I just found one, still in the original bag labeled:
Bulletin 2706
Renewal Part RIO CONNECTOR
CAT 46708-605-01
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
215
Is it possible to connect a PC to the mini console's RJ12 connector? use an RJ12/DB9 cable?
997
Do someone have wiring diagram of SLC 5/04 DH+ Channel 1 ( 8 pins round connector ) to CHA NETWORK of DL3500 ?HOW to set parameter of DL3500? I'm...
19
1,872
Hello, I'm looking for a source for the white connectors in the picture below. This controller has 6.3mm spade connectors potted into it in rows...
1,444
I have been trying to figure out how one of my technicians managed to obtain a "mini style" 18mm 5-pin T-tap that had crossover wiring inside that...
28
5,916
