RSLOGIX5000 and panel view plus 600 project.
sparkytex
Jun 2013
Port Hardy B.C.
354
Hello every one. I recently was given my first project to go ahead on, I'm pretty excited to get underway. We have a 1000 hp synchronous motor at the mill for chipping logs which has a solid state exciter on it. I installed the exciter and a co-worker ( which is my trainer ) had to replace the modicon PLC with a control logix due to issues with the modicon. He re-wrote the program on rslogix5000 and uploaded it onto the PLC and away we went. He now wants me to program a Panel view plus 600 to show the status of the motor when running in normal operation and have a fault screen with the list of available fault which will latch in the event of a failure. I attempted to upload the "small woodplant chipper" program in the downloads section under allen Bradley. I've never programmed a panel view before and am going to need some help for sure, not sure what kind of software I need. I have the PDF file from Rockwell on it but its quite confusing when it comes to programming the unit. I have all the addresses of the instructions in the program i'd like to use for the faults and running statuses for the unit. have a look at the program first of all to see if you can download it. thanks!
Your PLC program is downloadable.
You're going to need FactoryTalk® View Studio Machine Edition to program your PV+ 600
I made the recipe and it is all working. I made a user defined record element. I see the Recipe name (STRING) has LEN (DINT) and DATA (SINT(82))...
3,376
Hi all,I was reading about recipes in the forums. Bulletproof way seems to be in the PLC which I like. I have 2 words for the recipe 1 word is...
3,412
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
118
So I had an odd request from a customer for the above. I have written the logic and tested it all in one PLC with only using 7 outputs and 7...
427
Hello everyone, I have an RSLogix5000 project which is running live in the factory but I need to make some changes to the logic. I want to test...
1,121
