AB DH+ connector source
Ken Moore
May 2004
North, West, South Carolina
3,475
Hi Folks,
I have obtained a couple or used/refurbed Allen-Bradley DH+ components. However the three terminal DH+ connectors are missing. Local AB rep quotes $9.95 each for the connectors. Does anyone have an alternate source.
thanks,
Ken
Check with one of your reps that sells Phoenix contacts, or one of the other terminal companies. To get one I would say it should be no more than $.50. Then again how much is your time worth?
I couldn't believe $9.95 each either, so I called one of my buddies at Rockwell. He says list price is $11.00 ! We agree that's sort of a "nuisance price" that RA puts on little piece parts to discourage you from throwing them away with the packaging.
The Phoenix part number is MSTB 2.5/3-ST-5.08
MSTB 2.5 is a general category, 3 is the number of pins, ST is Screw Terminal, and 5.08 mm pin spacing.
You should be able to get them for a couple of bucks each from the mail order houses:
http://www.mouser.com/catalog/618/862.pdf
Funny, I think the connector has "Phoenix" written right on it.
What do you suppose the 110 ohm resistors go for? You'd better not lose one of them.
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
176
Is it possible to connect a PC to the mini console's RJ12 connector? use an RJ12/DB9 cable?
980
Do someone have wiring diagram of SLC 5/04 DH+ Channel 1 ( 8 pins round connector ) to CHA NETWORK of DL3500 ?HOW to set parameter of DL3500? I'm...
19
1,841
Hello, I'm looking for a source for the white connectors in the picture below. This controller has 6.3mm spade connectors potted into it in rows...
1,434
I have been trying to figure out how one of my technicians managed to obtain a "mini style" 18mm 5-pin T-tap that had crossover wiring inside that...
28
5,868
