ASI Power issue
qx100
Dec 2011
Zibo
Hello,All
Our company has one machine that installed ASI communication system .Total two segments,one repeater and two ASI powers.I measure the voltage between ASI+, - and grounding and found one power is around +-15V and another one is around+- 2~3V ,but the voltage between ASI+ and ASI- of both powers is around 30V. I can't understand it ,Could you help me ? Thanks!
I'm not familiar with ASI . . .
But my guess would be that one (or both) has a 'floating ground'.
As in it is not referenced to ground.
Poet.
AS-i spec is for +- ~15V from ground.
The second PSU is floating, and needs to be grounded. Without the grounding, you will see communication issues due to noise.
Greetings. I have an ifm ASi programmer that's getting a bit old and doesn't hold a charge very well anymore (in cold areas, I can only set a few...
2,546
I need a power supply for ASI-Bus. Usually we use dedicated modules for this, but we've got no spares right now. Could I use a standard regulated...
3,733
How can I integrate my S7-300 Simatic with the IFM AS-i Master AC1335 and its slave IOs, such as 2411 and Airbox 2041, into Simatic Manager?
116
I've been called to a site to assist with an ASi fault. The line has been down for a couple of weeks following a failure of the ASi power supply...
1,301
Hi folks, I had trouble with door switches on a machine I was working on today. What first appeared to be as a simple reed switch turned out to be...
729
