PV300 problem
ctw3
Dec 2007
Australia
25
Hi all,
I have a PV300 2711-M3A18L1 which was working fine, until yesterday when now on power-up, it lights the screen, but nothing is shown. The screen is just blank, but lit
Pressing buttons doesn't seem to do anything, and I can't communicate with it anymore.
Is it dead?
cheers
Charlie
All what I have found on this issue...
The power supply does not provide enough current...
I don't know if this is the case, but you may try to feed it from another source...
:confused:
- [font=comic sans ms,sans-serif]fuzzy logic[/font]
Thanks for the answer, nothing has changed in the power supply department, but, my 24VDC is only 22.5VDC, could this be the problem? Mind you, it worked fine for weeks on this supply.
I can't remember if the supply voltage was closer to 24VDC at the time of hook-up
cheers
:confused:
I to have seen the same thing. Cheap 24VDC power supply. Bought another and put it in parallel with the first one and all was good. And yes it did work for awhile.
ctw3,
check the amp rating of your power supply.
Mickey,
24VDC @ 1.3A
Should be heaps big enough... shouldn't it?
Could the low voltage coming out if the Power Supply be more of an issue you think?
cheers
ctw3 said:
Mickey,
24VDC @ 1.3A
cheers
That sounds like what I had at first too. Its been awhile but I think if I turned the power supply on first without the PV on and then turn on the PV it would work. But if the power supply was turned on with the PV on also it would sometimes have problems. Go figure. At any rate the extra PS worked.
If your PS is adjustable you might want to turn it up.
No difference in which order I turn things on. Non adjustable PS, I will go and buy another on Monday. Thanks Mickey
cheers
Hello all, I've utilized many threads on this site and gleaned much information throughout the years. Now the time has come for me to finally...
1,781
Hey, I'm trying to upgrading some old PV300 Micro screens. I have communication on RSLinx but I can't get it to where I can get to the program...
2,906
The question is at the bottom ... 1st the buildup. I would like to change a prgm that is in a PV300 Micro which is configured by Allen Bradley...
27
8,066
I am using an Allen Bradley PanelView 300 Micro with Panelbuilder32 software. I am unsure on how to assign a screen to a function key? (F1, F2...
3,060
Hi Guys, Is there any way to get the real time clock datafrom the PV300 to the Micro 830 ? I have figured out how to communicate from the PV to...
3,039
