PV300 Micro upgrading
coldkilla
Sep 2016
NC
Hey, I'm trying to upgrading some old PV300 Micro screens. I have communication on RSLinx but I can't get it to where I can get to the program. I'm fairly new to this. So what application should I be using to get the old program out of the screen?
Specifically, PanelBuilder32, part number 2711-ND3.
Because the PanelView Standard terminals have been out of production for several years, that software is not available for purchase any longer. But your A-B distributor or local sales office can assuredly help you out.
Just a heads up, plan your migration carefully. The best replacement (size, cutout, cost) is the PV800 4".
Free software with CCWB. Just like the PV300 Micro, the newer PV800 HMIs are made for small controllers.
But, there is no import of your existing HMI project file.
You will have to build your project from new.
You could use a PanelView Plus 7 and their new 4" terminal. It will let you import your existing project file, but it does not have serial ports and the project import is just as much work as creating a new project; PV300 Micro projects are usually very simple.
It's also more expensive, plus s/w $$.
FYI The PV800 and PanelView Plus have nothing to do with each other. Completely different software. So if you go down one path (ex. PV800) you will need new projects and software to use the other (ex. PVP).
Just like the other posts said, you need PanelBuilder. That will let you edit the project and see the tag addresses. I think it's better to use the PV800 and build a new project.
Hope that helps.
Hello all, I've utilized many threads on this site and gleaned much information throughout the years. Now the time has come for me to finally...
1,790
The question is at the bottom ... 1st the buildup. I would like to change a prgm that is in a PV300 Micro which is configured by Allen Bradley...
27
8,070
I am using an Allen Bradley PanelView 300 Micro with Panelbuilder32 software. I am unsure on how to assign a screen to a function key? (F1, F2...
3,064
Hi Guys, Is there any way to get the real time clock datafrom the PV300 to the Micro 830 ? I have figured out how to communicate from the PV to...
3,048
This morning there was a post in the Practice Area that I'm re-posting here for consideration by the Forum community, with some edits for clarity...
3,557
