how to determine low,high,and mean scaling for Omron?
kartika
Jul 2011
Lampung
31
hi all, need ur help again..
how to determine value for low scaling, high scaling and mean scaling for OMRON CS1W-AD081-V1? and what is mean scaling for?
i have read the instruction manual, for 4-20mA or 1-5 volt 0000 up to 0FA0, if i wanna use sensor 4-20mA to generate 0-200kgf/cm2...
how to define low scaling, high scaling, and mean scaling for this situation?
kind regards...
1st create your scaling (Scale3 Function) 2nd Create a stack with however many elements you want 3rd Use a clock pulse to diff move data into stack. Use min max or avg instructions to read the min max or avg values from the stack.
i'm still not clear, would u please explain me more? i have read an example of ladder about it
there is level transmitter 0-2500mmH2O its represent 0-100% = 4-20mA, use CS1W-AD081-V1 for analog input, and then for high scale is 5530 and low scale is 0, and mean scale is 5, where do they come from?
Hello, i am a beginner with a Siemens Logo 8 PLC. I would determine the direction of an object if it passes a whole cycle of 2 input sensors. See...
183
Hi all, Just looking through the CIP_AXIS_DRIVE data type in a Logix controller to look for something that can tell me whether the current...
1,070
I'm currently working on an MES interface PLC which passes around a whole bunch of strings. A lot of these strings are really just to allow for an...
1,118
I don't use AB much these days, and any installs I've done in years past have been setup by myself from scratch, so I've always known what...
2,082
Hello: I wonder if there is a way to find the CPU load of a Logix processor, and if it is not possible to determine this in an absolute way, I...
1,998
