CIP Motion Axis - determine actual direction of motion
ASF
Jun 2012
Australia
3,921
Hi all,
Just looking through the CIP_AXIS_DRIVE data type in a Logix controller to look for something that can tell me whether the current direction of motion of a CIP axis is positive or negative. Obviously I could chekc if the position is increasing or decreasing, but that takes multiple scans to reliably assess, and requires a lot of edge case catching to make sure I handle things like MRP instructions/position rollover/etc.
Does the velocity return a negative value when the axis is travelling in the reverse direction? Or is there some other element in the axis tag that can give me this info?
I somehow ended up with an ACD sample file that had been partially unpacked and the AXIS_CIP_DRIVE data type was visible within. Here's an XML of it. You can't import it as your own type due to the sheer member count, but it might be of some use anyway.
Hello everyone! I'm upgrading a "flowpack" machine using 1769-L36ERM, 5 Kinetix5500 with VPL motors and a 842E-CM encoder as a master. When...
1,576
I have run into several systems the last while that are using L43 CompactLogix processors to control 6000 series servo drives over a Sercos loop...
1,017
I have 5 Powerflex 527 STO CIP Safety drives being used as CIP Motion Control axis with control logix version 31.11 on a 5069-L340ERMS2 processor...
2,663
Hi I have a 1769-L27ERM with Kinetix 5500 and CIP motion. The application is a centre driven rewinder. I want to turn a shaft through a fixed...
3,185
I'm trying to get a better handle on how coordinated motion works on CIP drives like the 6500. From what I gather: CIP Sync is used to get the...
2,200
