CIP motion torque/Position modes
JasonWade
Oct 2005
Preston
160
Hi
I have a 1769-L27ERM with Kinetix 5500 and CIP motion. The application is a centre driven rewinder.
I want to turn a shaft through a fixed number of turns (at fixed speed) to engage the material, then switch to a torque limit, with maximum speed applied. Torque will then be gradually increased as diameter does. When the material is cut I want to go back to position mode and finish the winding, then come to rest at a known shaft angle.
My difficulty is that it looks like the axis can only be switched between these modes by a download. I can see that I can change the max/min torque (in position mode) and it takes effect immediately, but then the axis ultimately trips on speed error if torque limit is reached before speed is achieved.
Can anybody point me towards a solution? Thanks!
ok
you are almost there -
yes change the max torque positive using a GSV for torque control
Either Disable the Speed error (and position error) when torque control is active
OR use a MAM command that is targeting a position ahead of your current location and continuously update that position target using MAM with "merge" enabled
What you are trying to do is maintain the "Axis commanded position" far enough ahead of the actual position so the torque control can perform but not far enough to trip all of the errors (position error, speed error etc)
Gotcha's include how the drive is tuned (Position integral gains especially (If you have to you can change the gains on the fly as you exit and enter torque override control))
The drive not following the motion profile when exiting torque control
ok
Hi MichaelG thanks for the reply
I had thought about this way but couldn't find a way to turn off the error detection (or even raise the threshold).
Also I had selected the torque limit parameters for cyclic writing, rather than using GSV/SSV. Is there a good reason to use SSV instead?
oops my bad - SSV is the way that I changed max torque on a SERCOS system
the method that you are using is better - cyclic writing
Parameters I think that you are looking for
PositionErrorFaultAction - change from disable drive to "do nothing"
PositionErrorTolerance - Threshold
The threshold is set by the system during an autotune
Hi all, Just looking through the CIP_AXIS_DRIVE data type in a Logix controller to look for something that can tell me whether the current...
1,084
I have run into several systems the last while that are using L43 CompactLogix processors to control 6000 series servo drives over a Sercos loop...
1,025
I have 5 Powerflex 527 STO CIP Safety drives being used as CIP Motion Control axis with control logix version 31.11 on a 5069-L340ERMS2 processor...
2,691
Hello everyone! I'm upgrading a "flowpack" machine using 1769-L36ERM, 5 Kinetix5500 with VPL motors and a 842E-CM encoder as a master. When...
1,586
I'm trying to get a better handle on how coordinated motion works on CIP drives like the 6500. From what I gather: CIP Sync is used to get the...
2,219
