AlfredoQuintero
Hello:
I wonder if there is a way to find the CPU load of a Logix processor, and if it is not possible to determine this in an absolute way, I wonder if it is possible to compare some value under different conditions to see if one particular condition increases significantly the CPU load.
For example a year or so ago I wrote this post in answer to an inquiry on how to get CPU memory usage. It turns out there is this class ID 72 for Logix processors that gives this memory usage information. I am looking for, but cannot find, a similar object for CPU load. If it exists, is it possible to send a CIP generic explicit message to the CPU itself? Never done this.
Also, I tried to see if the GSV can support this or an equivalent. I wonder whether the below GSV object would be useful. Thanks for reading.
