ScottTheEngineer
I have an interesting problem.
A while back I had to do some PMing and rewiring of one of our control panels. None of this involved the PLC system or related connections.
When I threw the power disconnect up the Logix 5562 died with a solid red light. Hmmm. that sucks.
I pulled a new one out of the crib, powered it up and downloaded the program to it through the ethernet using my laptop. No problem.
Everything came up just fine.
We have a Control station on the floor that we use to go online with the processer through a series of hubs that link several Racks, SLC 5/05 processors and PV+'s together. everything shows up in RSlinx except the ENEt card in the rack with the new processor. The ENet card works because thats the module I went through to download the processor. It also communicates with several other devices.
RSlinx PRO shows a yellow ? I didn't change any settings in linx or the card.
I'm kind of at my whits end. the only thing I can think of is that theres an older version of linx on the same PC and I started that one. again, I can see everything else but this one particuler Enet card.
Anything I'm missing here?
All the I.P. and subnet info is correct and hasn't been changed.
