OK I just found a Inline Indirection in the RS500 instruction set. This allows you to insert integer and floating point values into ASCII strings.
I have been trying to write code to convert a Float to a String AND handle any errors that I get because of math overflows. So after a full day of nothing but junk code I found this.
If you are doing ASCII this might help
Flow rate is currently [N7:0] GPH and contains [F8:0] PPM contaminants.
Keywords to search for later when I can't find this
float to string
F to ST
float to string
F to ST
