Siemens TIA Portal V15 G120C Drive Firmware
bigsteve777
Dec 2013
The Land Of Chocolate
25
HI all! New to Siemens and was wondering when adding a drive to a project is there a way to select the Firmware of the drive when adding it?
I have a Siemens trainer with a G120 Drive FW 4.7.6. When I try and add the drive to the project the firmware is set at 4.7.10. Yes I know I can update the drive firmware but I was wondering if there was a way to do change it in the project?
Thanks in advance!
Thanks in advance!
WHen you add the drive, down at the bottom of the catalog is the "Information" section. You can select from the list of available firmware there.
You may be able to right click on the drive and select "Change Device" as well, but with drives sometimes you need to delete them and add them again.
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
446
Hello, If the date on the license manager of tia Portal has expired, can I still work with it? or is this just to keep the program up to date...
210
Hi everyone I've created an FC that includes the blocks TCON, TDISCON, TSEND and TRCV. This block has to be as generic as possible across...
1,519
Hello, i can find the CPU when searching for it. But when I go Online i just get the icon for "Not compatible" everywhere. I get no additional...
1,177
Hi, I want to initialise some tags on first scan only. As they are related to wall-clock time, I want to do the initialisation when the PLC first...
1,173
