Outputs After Countdown Timer
jessreyes
Aug 2012
California
I am using a Horner XL100 and am trying to make a countdown timer that starts when a button is pressed. After the timer runs out (goes to zero) it needs to trigger an output.
So far I am using an Off-Delay Timer to count up and a Subtraction function to output a countdown on the screen.
I have tried using both a normally closed and normally open coil after the timer. These don't give me the output I need.
-|I2|-----------[TOF]----------------(M1)--
-|M1|-------------------------------------(Q1)--
Here is basically what I have so far. My goal is to get an output at Q1 only after a certain amount of time and only after I2 has been pressed.
Can anyone help me with this problem?
-Jess
Yea. I did.
But anyways I figured it out! I just added an Equals function. So once the countdown equals 0 then an output is seen.
Thanks!
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
103
Problem: Our PLC can only output 4-20mA, but the actuators it needs to control, modulate based on a 0-135Ohm signal. Buying 4 or 8 individual...
275
Does anybody know how 'timestamp output' functionality internally works in a controller? I do not mean the instructions you use as a programmer...
68
Hello, I am stuck on trying to get an ArmorBlock, 1732E-16CFGM12QCR to respond to EIP outputs. My PLC is Panasonic FP0H-C32ET. I Registered the...
132
Hi all so i have a robot project im working on were i need to set the layers. using the hmi screen i would like to use the numeric data display to...
823
