Logging signals with Fluke
aand74
Dec 2005
Deinze
131
We want to log three analog signals (2 X 4-20 ma + 1 x 24V DC).
Later on we want to plot the three signals on the same timebase.
We will be using following Fluke components :
- FLK-A3004 FC, item 4629301 (WIRELESS 4-20 MILLIAMP DC CLAMP METER)
- FLK-V3001, item 4459421 (WIRELESS DC VOLTAGE MODULE FC)
- FLK-PC3000 FC 4401602 FC Wireless PC Adapter 101.0
These are wireless meters that are read by by an adapter of Fluke in the USB port of a pc.
Has anyone experience with this system?
My doubt is if the the data received from the wireless meters are on the same or almost the same timebase of each other.
Because my signals will be a setpoint and a corresponding actual value.
So if the timebases do not match clearly, I won't have a reliable plot in function of time of both signals.
I would just contact Fluke. They should be able to tell you if the equipment will match the application.
Regards,
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
65
Hi, Wy we log data in PLC using DLG instruction, when we have option to log data in HMI
80
Hi everyone id like to start by saying im not a PLC programmer so my technical terminology is limited. i would like advice on what software is...
297
After the new very nice update to this site I could not log in with my original password, tried to recover my account but did not recieve a email...
395
I have some datalogging set up on an S7-1211. Most basic controller, but 1MB of memory should be enough. A single log is 222 bytes and logs an...
416
