Siemens S7-1200 Datalogging
Puddle
Mar 2022
UK - The Norf
331
I have some datalogging set up on an S7-1211. Most basic controller, but 1MB of memory should be enough.
A single log is 222 bytes and logs an array of 21 UInt tags, plus a timestamp while logging is active.
However! After 5 logs of a single entry it's telling me that it's out of space. Yes it's a very basic CPU, but according to the diagnostics page on the web server each one of these logs consumes 132.11KB.
Am I missing something here? Even if I used an MMC it would fill up much faster than I thought here.
Error 80B3 for insufficient storage, which is right because it was showing load memory at 93.2%.
My concern is that it should be taking 222B, which is the size that the csv file is when downloaded, but when that datalog is deleted it frees up 132KB.
I'm also pretty sure that I've had some much larger logs stored on that PLC with no memory card.
That did help. I had it set to 720 logs, logging every 2 minutes for 24 hours maximum. So the PLC seems to reserve the data of a full size log, so even though the actual data is shown in the file size, that may only be for 1 instance with 719 in reserve.
I would have expected that data to become available once the log is closed however.
I've reduced this so the maximum number of logs won't touch the memory limit.
I'm still missing some information as to how much data is used though, as the log size is about four times larger than it should be when adding up the data contents. I can't find a resource to show what data is used.
EDIT: I've worked out where the data is going. I was thinking in terms on PLC data types, but it's saved as a CSV file. When opening in notepad, there are 217 characters which are a byte each, plus 5 bytes for the file name.
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
255
commentaire communiqué siemens s7-1200 avec vfd delta ? (cablage et sur tia portal )
135
Hi, I have a 1214 on ip 192.168.0.100. This is connected to other modules through a switch on same network. I need to connect this to a company...
182
Hi Experts, I would like to make firmware upgrade from v3.0 to v4.5 (S7-1200 CPU 1215C). Can I do it from v3.0 to v4.5? Do I need to take some...
293
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
2,880
