Database with AB Solution
plcengineer
Jan 2004
USA
176
I have a project that involves a Versaview PC, RSView32, Controllogix and a Kinetix 6000 Drive connected on a Sercos Comm network. I have approx 150 data points that I need to have in a recipe function. Should I use the recipe function in the RSView32 or look at a SQL solution? I need to be able to let the operators build a recipe and then load the machine with the recipe once it is complete.. Let me know of the best solution. I am not a SQL or database programmer so if the solution involves heavy database code, I would rather stay away from it.
I've found that both of the recipe options in RSView32, inherited from ControlView and WinView, are inadequate for any significant recipe work.
You most likely will want to make validity checks on the data entered and flag any errors as they are entered.
You can use the included VBA and store recipes as text files if not too involved. Otherwise, you will most likely need to consider VB and a database.
I’ve been tasked with extracting PLC (logix 5572) realtime data, storing it in a database (anything compatible with our data) and displaying it in...
28
We are a water/wastewater plant, collecting realtime and manually entered data. We have been using FactoryTalk Historian (OSI PI) for real time...
127
Hello to Everyone all over the world: I don't want to reinvent the wheel so I am asking others if they have programmed something similar to this...
289
I have an Access database that I need to pull information from and display in a FactoryTalk View ME station. Is there an easy way to do this?
230
Hello, we have two PC with the FT SE local application and the same project. The one PC is wrong about alarm and event log. When I open the...
466
