I'm laying the groundwork for a system that will allow prompt the operator of a forklift to retrieve a certain pallet and load it onto one of four waiting trailers. Confirmation of the correct pallet will be accomplished using the scanner to compare the barcode on the pallet to the one sent to the HMI from an external data source. In order to verify the correct trailer is loaded, I'd like a second scanner pointing up from the cage of the forklift to read a permanently-mounted bar code on the door header.
It'd be great if I could just mount an HMI on the truck, plug a suitable scanner (or two) into it, and communicate via a wireless client adapter to an access point.
If this isn't possible, I could also mount a Micrologix 1100 on the truck with suitable serial adapters to connect the scanners to.
Does anyone have recommendations and/or hardware suggestions?
