Hello everyone,
Hope someone can help me, I'working with a S7-1200 project where I added two Keyence vision sensors via profinet (using the GSD file), and it worked without issues, but then I needed to add another inputs (some discrete sensors) and because some space issues I had to add an external module, I chose a Balluff IO moudule (4 I/O and 4 configurable ports) that works with Profinet.
I got the GSD for the Balluff module and could add it to the projet, I can also assign the IP address and whis works fine. Then I have to configure the module to be able to work with it, but I can't figure out how, when I go to the configuration screen of the module I see at my right all the configurations I can choose to add in each slot, I've tryed a couple but because of the hardware not being correct, my plc goes to fault mode.
Does anyone had work with something simillar?, I need to work with 8 discrete inputs on this module.
Hope to hear from you.
Best regards
Juan
Best regards
Juan
