How configure Balluff IO Module with S7-1200
juanmdx
May 2007
SLP
281
Hello everyone,
Hope someone can help me, I'working with a S7-1200 project where I added two Keyence vision sensors via profinet (using the GSD file), and it worked without issues, but then I needed to add another inputs (some discrete sensors) and because some space issues I had to add an external module, I chose a Balluff IO moudule (4 I/O and 4 configurable ports) that works with Profinet.
I got the GSD for the Balluff module and could add it to the projet, I can also assign the IP address and whis works fine. Then I have to configure the module to be able to work with it, but I can't figure out how, when I go to the configuration screen of the module I see at my right all the configurations I can choose to add in each slot, I've tryed a couple but because of the hardware not being correct, my plc goes to fault mode.
Does anyone had work with something simillar?, I need to work with 8 discrete inputs on this module.
Hope to hear from you.
Best regards
Juan
I don't have a card like that at the moment but from what I can rememeber after you add the item to the project you had to open the device under:
Project tree > PLC > Distributed I/O > 'Your device'
I think this is where you would configure the IO / diagnostics
hi all i am new here i have a mitsubishi smart touch hmi i.e ms-60t-pe but i cannot find a software to edit and download a program in it any help...
163
Hello, I am trying to connect a Stride Analog Output module to a 1769 CompactLogix via Ethernet. I added a new Generic Ethernet Module for the...
240
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
152
Hi all, the machine I am programming the Rockwell PLC for has about 100 parameters that need to be adjusted for every customer. I would like to...
20
1,979
Within the last week or so, PME has crashed whenever I try to open a configure IO screen. I am running V8.0 Build 6215. Offline configuration of...
401
