cattiebrie
Hi, I'm a returning student (over 10 years out of school) and I'm a little lost in my course. Can someone please come up with a program for this process? I want to use your answer in my LogixPro and see how it functions, that way I can learn from your answer.
Write a program to implement the process illustrated. The sequence of operation is to be as follows:
• Normally open start and normally closed stop pushbuttons are used to start and stop the process.
• When the start button is pressed, solenoid A energizes to start filling the tank.
• As the tank fills, the empty level sensor switch closes.
• When the tank is full, the full level sensor switch closes.
• Solenoid A is de-energized.
• The agitate motor starts automatically and runs for 3 min to mix the liquid.
• When the agitate motor stops, solenoid B is energized to empty the tank.
• When the tank is completely empty, the empty sensor switch opens to de-energize solenoid B.
• The start button is pressed to repeat the sequence.
