Import and overwrite program while online with a 5570
theColonel26
Feb 2014
West Michigan
785
I am trying to import and overwrite program while online with a 5570. I swear you can do this with a 5580.
I even tried inhibiting the program.
So after I close the import dialog (which seems to tell me nothing about what the issue is) I look at the logs and this is there
Warning: Program 'my_program' will not be imported. Unable to create or modify all tags and routines of program.
:confused: So
ideas?
I updated AOIs by doing the usual rename the tags and the UDT type names.
Update: I still had more AOIs that needed their instance names changed. :sick:
Also always remember to set your UDTs and AOIs to none external access other wise some *** hole might reference them from FT View and then Studio 5000 won't let you delete them......
I'm trying to import a .prj file and I keep getting the error message: Project import error. i Any ideas how to get around this? Thanks.
78
Good day colleagues, I have a problem with a plc slc 5 since I export the tags to my factory program to load them into a panel view 1000 plus 6...
118
hey good afternoon ! I have a simple question, I need to import an Add on instruction to a controller that is in operation and cannot stop. Is it...
298
I am very familiar with Studio 5000 PLC programming. And I'm very familiar with C-More HMI programming. But this is my first time using a C-More...
316
I am trying to import addresses and symbols from a PanelBuilder32 application into the RSLogix 5 Address/Symbol database - however each time I...
539
