Slc 5/05 & Rslogix 500
Jimmy Duncan
Jun 2003
north carolina
I HAVE A PROBLEM I NOW SOMEONE HAS THE ANSWER TO SO HERE IT IS. I HAVE A SLC 5/05 THAT I CAN ACCESS USING RSLOGIX 500. I CAN VIEW AND EDIT THE PROGRAM BUT NONE OF THE DESCRIPTIONS OR SYMBOLS IN THE PROGRAM SHOW UP ON MY COMPUTER, THE ADDRESSES AND EVERYTHING ELSE SHOWUP BUT NO DESCRIPTIONS. I KNOW THEY ARE THERE BECAUSE I HAVE SEEN THEM ON OTHER CORPORATE TECH COMPUTERS, COULD THIS BE DUE TO DIFFERENT VERSIONS OF RSLOGIX OR IS THERE ANOTHER PROBLEM? I'M NEW USING RSLOGIX 500 SO I'M NOT SURE IF THIS IS THE WAY I HAVE IT SETUP OR NOT.
THANKS JIMMY
Jimmy,
You need to have the original source code on the PC your using to access the SLC as the comments are held here and not in the PLC processor itself. So get a copy of the code from one of the other machines you've seen with the comments and use this to go online from yours and you should see the comments.
Jim
Jimmy
Unless you have the original program or a copy of it on the computer you are using you will not see the descriptors in the program. AB's new Logix line, ControlLogix, CompactLogix, etc got away from that problem by saving all the program info in the processor instead of the programming computer.
Dave
Control logix and compact logix only hold the equivalent of the RSLogix500 symbol in the processor. Bit/word description and rung comments are still held offline. Regards Alan Case
You only have the ladder logic file on your computer, you will need to copy the description & comments files to your computer. Copy them, ladder & comments, to disk from one of the other computers then save them on your computer.
I am not sure if you have the option of "SHOW/HIDE COMMENTS", if so then make sure you have selected "SHOW".
Roger
Hello. I am trying to change the indexes when I Paste from SLC Library and I must be doing something wrong. I tried it with a very simple rung to...
1,428
Hi all, yesterday I was at a customer site doing a PM and after making a couple of minor mods to the program, I went to back it up to EEPROM (yes...
2,397
I have a few projects I want to Save As file type SLC to be able to use the Translation tool in Studio 5000 (migrating from SLC 5/03 to...
2,503
Hi all, Sorry to make my first post a request, but I was given this .RSS file and need to convert it to .SLC - would some helpful person with...
4,519
Hello. I am learning Allen-Bradley PLC programming using the RSLogix 500 emulator. So I need some help pls. I am using the RSLogix Microstarter...
4,261
