Tom12345
(note the A.S.S is without the full stops, forum seems to be filtering it as rude word)
Hello all,
Hoping someone can help, I'm trying to achieve the following:-
- I want pass a value to a genie
- I want to then pass this to a pop up window function and use the value as an INT array index.
The part I'm not sure about is the correct way to use the 'A.S.S***' function
A.S.S(-2, 1, "ArrayTag" + "[" + genieindexvalue "]", 0)
This compiles ok, but when I put into runtime it seems as though it is looking at the entire array when I press Ctrl + P on the pop-up.
Even if I put an array index, it seems to be looking at the entire array without the index
A.S.S(-2, 1, "ArrayTag[5]", 0)
The prefix method works fine, but I don't want to have 50 variables with prefixes.
A.S.S(-2, 1, genieindexvalue + "ArrayTag", 0)
Any help would be much appreciated, I tried the cicode manual and website, it only gives examples of prefixes and the ability to add an index to the pop up string ?INT 1?[XXXX - array index} which isn't useful as I want the array index to be passed through via the genie.
Best Regards,
Tom
Hello all,
Best Regards,
Tom
