Autosketch vs. Autocad
Aug 2007
Hamilton, Ohio
151
I know this is not a plc question (forgive me), but I am wanting to learn to make electrical drawing using Autocad. However, I don't want to shell out the bucks for Autocad and was thinking about using Autosketch since the files are compatible with Autocad. Has anybody here had any experience with Autosketch?
Yes, I can vouch for SEE Electrical. We use the Basic version. You can get a trial of the full version for 30 days.
I have attached a couple of little examples I have done.
I just downloaded ProgeCad 2008 Smart which is very similar to AutoCad, and free for private use.
I have only piddled with it for a few minutes, but so far it accepted the same commands as Autocad.
I would suggest something like that, so that once you learn it, you will also be familiar with Autocad, which is a very marketable skill.
Paul
Thanks for all of the advice, links, and drawings (those are real nice looking drawings).
At a quick glance it appears that OkiePC's route is the best way to go since what I'm really wanting learn is Autocad - which is a marketable skill.
I second this suggestion. And here is the link:
http://www.progecad.com/compra/index.asp?left=prodotti/eng_progecad2008smart&abspage=1&lang=eng
Intellicad is also an option, it is relatively cheap and will directly open autocad files and will also save in autocad format. The commands are also very similar to autocad
Anybody have AutoSketch? I have 11 .SKF files that I need converted to .DWG. From what I can gather the file extension belongs to AutoSketch and...
4,360
Hi Expert: I have used EPlan at previous job, now in the new job they use AutoCAD Electrical, just finished one training at Udemy, it is not good...
1,146
When I started as a controls engineer way back in the ‘80s everyone used all caps when documenting PLS programs and in AutoCAD. This was still...
1,662
Hi everyone, this is a bit off topic and support has not gotten back with me. I am using Autocad electrical and i need to do some mechanical...
1,461
