FTV ME Display number
bella
Mar 2013
Montreal
Hi all,
I hope someone can help me with this. I have one PV+ 1500 which communicates with a PLC5 through RIO. I want to add some displays on the same PV+ that will communicate with another PLC (ControlLogix). My problem is that in both PLCs I need to know the current display number, but in the global connection I only can put one tag to get this info. Is there a way to share this between two tags (one for the PLC5 and the other for the CLX)?
Thank you for you help.
Under Global Connections>Macro tab. Remote Macro 1-5
Create a Macro and name it Macro1 thru Macro5 which ever one you use. ( this must be the naming convention used as shown in help file) copy Replace Display Number to your display tag for the 2nd PLC.
Use the Replace Display Number to run macro.
I created a memory tag that gets the info from the global connection (Replace Dispaly number) and used it to run a macro that copies its value into the corresponding tags in each of the two PLCs.
Thank you once again!
Hi to all, Does TIA portal support creating reusable pop-up display as FTV has it implemented? Something like on link below. Thanks in advance.
531
Hello, I'm having an issue that I did not expect to run into. Using FTV SE v11.0 (CPR 9 SR11) I've created and saved a global object inside the...
1,510
I have a bunch of devices on my displays that are the same. I have build a global object for them and is working great. I want to place a button...
1,953
Can you help me with the following? I know when creating an expression using the "display" command I can use different switches to cause the...
1,022
Good afternoon: we have existing HMI created by FTV studio ME V8.0 which connects PLC1-roslogix5000, now we want to add one numeric display (its...
1,700
