Edit a .L5X and reimport it?
Bob O
May 2003
1,873
Is it possible to edit an .L5X file and then import the modified file?
I’ve used notepad, notepad++ and XML Notepad to modify and various saves and save as combinations but all have fail. I'm attempting to change a tag name. Is it possible and if so what the he** am I doing wrong?
Error: Unable to Parse the L5X content
Thanks,
Bob O.
I think I got it. I selected Match Case and Use regular expression in XML Notepad for the replace and then just save.
Thanks,
Bob O.
I used to export/import regularly.
I extracted data from the file, loaded new data into arrays. A bit different from what you are doing.
Don't change the number of lines in a section.
Don't let your editor change spaces to tabs. Leave everything as it was originally except what you want to change.
.L5K has had a bunch of stuff added as they released new controllers ... I'm a few years out of date.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
133
Searching edit zones within all routines and other criteria still says no results found, yet I still have the "edits present" indicator at the...
253
Does anyone know where I can get TouchWin Edit software version V2.C.5 or above? Xinje's website is lacking. I just got a newer TH765-N display...
170
I have a FactoryTalk View Se project, Is it possible to export Direct Reference tags to edit in a CSV file or Excel? I know I can export HMI...
290
Hi everyone As a topic title, I want to edit ALARM01_1 ALARM02_1 ALARM03_1 .... ALARMxx_1 to ALARM01_2 ALARM02_2 ALARM03_2 ...
389
