Logix Designer showing Edits Present but shows no edit zones on search.
HazMatt
Feb 2024
Kentucky
Searching edit zones within all routines and other criteria still says no results found, yet I still have the "edits present" indicator at the top. Anyone run into this before?
Yes, I have tested that myself when online with 2 different computers.
If another user is making edits that aren't part of the upload or offline file you have then you will get kicked offline.
Is there another programmer on your site? Or the PLC connected to the internet?
Thanks for the replies guys. To give some background, I am converting a PLC 5 program to a control logix one. I am offline. I am actually consolidating a currently running PLC 5 into a currently running Control Logix. I had this same issue when I installed the last PLC. It was a fresh program that I made and was testing, but I still could not find edit zones (they were there but the Find function was not working. I had to scroll through to find them).
How do I organize the template for my controls. I am new to Logix Designer but have used RS500 and RS5000. My new Logix Designer has Toolbars...
236
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
136
Does anyone know how to set the background colors of instuction blocks (TON, MOV, etc)?
134
Hello all, I'm trying to use the Logix Designer SDK to upload and download a single ACD to many controllers. I got this to work fine copying...
68
Hello, I am trying to connect a Stride Analog Output module to a 1769 CompactLogix via Ethernet. I added a new Generic Ethernet Module for the...
235
