O.T. - Multi-Monitor Arrays?
damica1
Aug 2015
Illinois
839
If this is Off-Topic please just delete!
Is anybody using Multi-Monitor Arrays with screens as large as 40" or bigger?
I'm getting ready to update our DATA CENTER with 8 (40" screens) and can't find a mounting solution.
The problem seems to be the larger screen size (40") I have reached out to several manufactures of mounting hardware and they all only make arrays for up to 27" monitors.
Nobody using 40" or larger screens for they SCADA systems?
How about this...
https://www.standsandmounts.com/PremierMountsFloorStand-PSP-60B.aspx
You would need 4 of them but you could mount 2 on each poll and you could just spread them apart to fit the 40"
Or I would contact them, they have just about everything so they should be able to help
Are they all running off the same PC? I am due for another upgrade, I was looking at Dells with Radeon Pro WX5100 and running them off HDMI adapters, they are not high end but I think they will be better than what I have, my new shop has a ridiculous internet speed but my PC's are sloooower than ****, my speeds are about 400 download but its like I am running on dial up :)
Yes, but we just wall mounted the the televisions that we used. Hard to imagine a multiple monitor desktop mounting solution for monitors larger than 27". I have done quad mounting of 27" monitors though.
We use channel like 80/20 and use generic mounts. If it’s a video wall usually you do need any mounts that articulate so the channel makes it so easy to get perfect alignment. There are companies that make video walls where the monitors snap into each other but are usually ungodly expensive.
Hi All, Good Day y'all. I'd like to know how to setup multi monitor using Wonderware Intouch Standalone Project. We have 4 monitors in a rack...
1,232
I have an HMI project on FTView SE Network Distributed and had originally intended for the operators to have a client runtime running on each of...
1,048
Hi, im running citect 2016 with 4 monitors. i have used the multimonitors paramiter in the config.ini file and set to 4 but for some reason it...
2,814
Just a general topic of discussion. What HMI package out there that support Multi-monitor? I suppose it's in their interest to sell you as much...
4,251
Hello, Do you know if instead of using a Siemens multi monitor video card 6ES7652-0XX04-1XE1 I can use another multi monitor video card i.e...
2,713
