GE QuickPanel+, Historical Trend Duration Time
android94
Nov 2015
Cali
Good day for all of you.
I got a Historical trend i have configured on a QuickPanel+:
Scan rate : 30.0, Pixel scale: 1
with the purpose of see a big portion of time from process logged data in one
sight.
When i switch to scroll mode, the "scan rate" became unavailable (i can not
change it from the menu that pop from touching the trend) and i only can see
11 minutes of data in one screen, more or less five samples only (my guess
is the scan rate automatically change to 0.1). I need see more data in one
screen, increasing the period of time visible, the so called duration time, in
scroll mode to be able to see unless 3 hours of historical data. This is
needed because the process has a long cycle.
¿How can I manipulated Scan rate in scroll mode of Historical trend ?
¿There is another way of trending long periods of historical data on QP+ ?
Thanks.
Hi, I'm trying to get an historical trend working with ME 9.5 SIM20. Here's the step done: 1- The Logging Groups - Logging type = View...
1,204
Hi, I received the following project from a customer on a QuickPanel Proface 6" that I need to swap to a Siemens Panel. However, I cannot seem to...
365
Dear colleagues, hello to everybody! I have a problem with Quickpanel IC754VBI06SFD-GF Proficy Machine Edition Runtime 6.5 QuickPanel View V2.00...
681
Dear guys, I am not a programmer but I can do simple things myself. I'm stuck with the following. if I want to extract a value from my rx3i...
46
4,866
does anyone know if you can make a graphical panel with the quickpanel+ 7inch that you can only open with a password? for example a panel where...
1,850
