Rx3i/quickpanel+ VB Script
How does O_prog_1, which is a single value in the HMI(?), comprise (get created from) %R02435 and %R02436, which are two values from the PLC?
Could you instead get the two 16-bit signed integer values for %R02435 adn %R02436 from the PLC into two integers in the HMI? Then it should be trivial to combine them into a single 32-bit signed integer using VBScript in the HMI.
The answer to your first question is: correct.
to your second question: I will try the second question tomorrow. I do think it is possible. that's exactly what emerson's support said.
Maybe this will help.
The HMI screenshot shows two different variables, even though they are both looking at the same address in the PLC. The top one displays the variable "HMI_DINT" which looks directly at PLC address %R10.
The bottom one displays the variable PLC.PLC_DINT, whick looks at the PLC variable "PLC_DINT", which is a DINT addressed to %R10 and %R11.
PLC_DINT has a value of 123456.
The PLC and HMI must be targets in the same PME project for this technique to work.
can I use that for the vbscript? I'll try that tomorrow and immediately put it in the script to see if the correct value is logged.
Hi all, I'm trying to setup communications between an RX3i PLC and a GE QuickPanel View touchscreen. I have a CPU315 (IC695CPU315) with an...
4,763
I have a system using Rx3I CRU320 redundant CPU with Proficy Machine Edition Software. In the hardware configuration of each CPU module, under...
389
Hi, we are using Rx3i CRU320 redundant PLC system and we noticed a discrepancy between Primary and Secondary controller. Couple of variables (DI)...
284
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
106
Hi there, Trying to get some ascii serial communications working via RS485 (COMMREQ functions). I have attached our wiring for the COM2...
977
