Custom made wiring harness
sparkyinak
May 2016
Ketchikan, AK
79
A recent project I did required custom made wiring harness within the panel. I'm not happy how they looked when I was done with them because the wires "did not flow together" like a good clean wiring harness should. It be worth the time and expense to take the time to calculate each conductor length if they were massed produced but what is a good way of making good clean wiring harness for one time projects when they will be exposed, not hidden by equipment or wire ducts? Is there software or methods that can crunch the numbers quickly?
Don't even attempt to prefab a harness for such an application. Start wiring at one end and build the harness as you progress toward wiring the other end, cutting each wire slightly longer than it needs to be in the finished harness. This is how we wired large pushbutton and relay panels back in the day.
I use short lengths of flex conduit to run between the back of the enclosure door and the panel:
https://www.automationdirect.com/ad...exible_Non-Metallic_Electrical_Tubing/GSI-20K
Unless it's just a couple of wires, the flex is much easier to use, and it looks REALLY slick. Size the flex larger than you think you'll need... you'll need the extra room.
I usually use 3/4" flex, and I use these connectors and brackets to anchor the run(s):
https://www.automationdirect.com/ad...mity_Accessories/30mm_Mounting_Brackets/ST30C
https://www.automationdirect.com/ad.../Non-Metallic_Liquid-Tight_Connectors/RPS-20K
I install a run (or several) of small wire duct on the back of the door, for dressing wires to switches and devices.
-rpoet
Experience is the only way you can learn how to wire the one of panels.
We contracted with a company for wiring harnesses and it took 6 tries before we got close, and on the 9th on we got it right. then on # 13, the customer made a change, after 4 more, another change was made.
there is no real way to make a wiring harness for one of panels the way you suggest. We use wiring duct for our control panels.
regards,
james
Use any type of duct,make the wiring and then remove the ducts.
I sometimes use some simple wood and some tye wraps to keep the wires a bit in direction.
Thank you for all the feed back. I do use wire duct. The particular project required harnesses for quick swap out of components so some slack had to be allotted for the functionality for the harnesses where wire duct was not practical due to space constraints within the small panel.
Hello friends. Does anyone know if the cable used to communicate between a PanelView 300 and a MicroLogix 1400 (via the DF1 port) needs to be...
1,227
Good day! I am working on a project at our campus to integrate fleet vehicle chargers with load management so we don't overwhelm our service. The...
37
3,912
I imported a customised shape into the project, but I don't know how to actually add into on to a specific HMI screen. Do I use the Graphics menu...
682
I'm testing the ability to make a custom ActiveX control for PVP7 applications to be able to write data out in an XML format. With my simple...
710
I am having difficulty finding documentation or examples on integrating Visual Studio with iX Developer in order to develop custom objects...
556
