Kinetix 300 - Send Position Setpoint in EtherNet/IP External Reference Mode?
Grendizer
Apr 2012
Toronto
88
Hello All,
I want to tell a motor to travel 50" away from an absolute position (Home Position).
How can I accomplish this in Kinetix 300?
Currently, I am using MSG instruction to Read Assembly 113 and Write Assembly 114. I can:
1. read status
2. start motion & homing
3. stop motion & abort homing
What I need:
1. tell the motor to travel specific number of inches.
I tried:
1. CommandPosition (in Assembly 114)
2. Target Position (ID = 184)
Couldn't get the motor to start.
What should I do? Am I understanding right?
Thanks all,
I got it to work!
The problem was (for the people who might have this problem in the future):
In Assembly 114, elements:
8...11 (L105:3) (stored in REAL F100:0 by choice)
12...15 (L105:4) (stored in REAL F100:1 by choice)
16...19 (L105:5) (stored in REAL F100:2 by choice)
20...23 (L105:6) (stored in REAL F100:3 by choice)
24...27 (L105:7) (stored in REAL F100:4 by choice)
28...31 (L105:8) (stored in REAL F100:5 by choice)
They need to:
CPW
Source #F100:0
Dest #L105:3
Length 12
Data had to be copied from Float to Long.
Cheers,
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
174
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
169
Hello PLCS.Net Forum, First time posting. Let's assume I am a novice. BASIC PROBLEM: My servo/linear piston is no longer zeroed to the...
263
Hello. I have a few machines that use Kinetix 300 (each machine has two drives). Both drives on one of the machine keep losing IP address. They...
117
Hello, We have had a machine running for the last 10 years. It has 2 x Kinetix 300 drives. Around a year ago, one of the drives failed. We were...
471
