Connection status GSV ideas
JeffKiper
Jun 2006
Indiana
2,460
I have a bunch of I/O on Ethernet. Does anyone have an AOI for checking the I/O connection? I usually do an Alarm after a GSV and some logic. Well I'm looking for a way to clean up the logic and streamline it.
Also see a recent thread on integrating this GSV in an AOI.
http://www.plctalk.net/qanda/showthread.php?t=118476
I have 2 AOI's in my custom library- one for Post RSLogix5000 V24 and PRE V24, both of which also encapsulate the reset logic and fault bits. In brief the older versions of RSLogix5000 wont allow you to incorporate a GSV in your AOI so will need to be read in beforehand.
collinsd70 said:
...In brief the older versions of RSLogix5000 wont allow you to incorporate a GSV in your AOI so will need to be read in beforehand.
Not quite...
We all should try to be careful in how we recall our understandings of things or how we have read and interpreted things. I myself had made a poor recollection on something in particular in that thread you have linked and after a helpful prompt from daba I was back on track.
What we were discussing as a limitation in that thread was not that one cannot use a GSV instruction in an AOI in pre v24 projects. What we were discussing was the fact that one cannot use a GSV in an AOI in a pre v24 project with the predefined generic "MODULE" data type as an InOut parameter. This is because this particular and special data type was only added at v24.
For pre v24 projects, one can indeed use a GSV instruction inside an AOI and can, if required, use a specific module-defined data type, of an I/O module that has been added under the I/O Configuration, as an InOut parameter. This is what daba demonstrated in post #19 of that thread.
Also, for further details on implementing a GSV/AOI method to check a module's status, I had provided a couple of Knowledgebase technote article links in post #10.
Note: Get System Value/Set System Value (GSV/SSV) instructions have been around since the dawn of time, or there abouts, but the Add-On Instructions (AOI) feature was "only" added in RSLogix 5000 v16. So only v16 or above projects can use an AOI with a GSV and a specific module-defined data type. And only v24 or above projects can similarly use an AOI with a GSV and alternatively the generic "MODULE" data type, which allows a user to select whichever module-defined data type they require when instantiating the AOI instruction.
If anyone is still not clear on this distinction, between specific module-defined data types and the specific "MODULE" data type, then please let us know and we could try to further demonstrate the difference with illustrations, if time permits.
Regards,
George
George.
Yes- I meant specifically the 'MODULE' data type, not GSVs in General (sorry..I should have phrased that a bit better).
Regards
Daniel.
Not a PLC question but I need expert help on this. My FactoryTalk stopped communicating with the server its hosted on. I had an error stating...
106
Hello, M340 plc. 3 standalone citect scada applications. Connection type (OFS server). Same application on all 3 stations and multiple logins to...
1,847
Hello- I would like to know if there is a way to monitor the status of a master connection to the EDS module on Rx3i rack. I have a master...
1,245
Hello Guys, I am using Ruckus P300 Root and Non Root bridge. I need to show the connection status and the signal strength in wonderware Intouch as...
1,156
Hi all! Trying to figure out if it is possible to monitor connection status in my program (like device status). We generally use our own...
1,494
