Hello-
I would like to know if there is a way to monitor the status of a master connection to the EDS module on Rx3i rack. I have a master connected to two Rx3i systems via EDS modules, but only one system should be active at a time. I'd like to use the "slave-master active" status bit to block the standby system from logging change events to its EDS module. If anyone could provide an advice it would be greatly appreciated.
I took a look to the module's user manual (GFK-2911B), found a small paragraph on page 57 mentions a bit about status of a master connection but not much help.
Thanks.
Thanks.
