How to change top of an Bitmap object in wonderware intouch
tayfun
Aug 2009
istanbul
Hello ,
I have a problem in wonderware intouch whose version is 10.1
how can I change top and lef of a picture object?
I would like to get top or left value of selected Picture object.
All function had been done for activex .
Actually I like to do that . I have a picture object whose name is yellowpictureobject was painted with yellow.
when I select any picture object whose name is selectedpictureobject.
I must get top and left values of selectedpictureobject.
after that I would like to change left and top of the yellowpictureobject with this new left and top of selected picture.
for example that are ;
yellowpictureobject.top=selectedobject.top;
yellowpictureobject.left=selectedobject.left;
Note :
Actually a Bitmap object has no name if you like you can see .
I gaved a name the pictures in order to tell you easily .
Thanks a lot.
Kindly, we are running the below cnc machine, after finishing a control and servodrives upgrade. But, we are having some problems to stop the tool...
2,118
IT has adoped a hardline policy - I cannot change the IP address on my laptop and they have locked it down - its set to get a dynamic IP address...
25
8,877
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
25
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
85
Hey all, i have a panelview screen (image attached), with 4 items on it. Program 1, Program 2, ...3, ...4. The PLC i am using is a compactlogix...
171
