servo control with Schneider Modicon
lesmar96
May 2017
PA
520
I have done various logic PLC programs, but I am just learning in the world of servo and motion controls. I have a small project here that I would like to use to learn more details of a motion control system.
I would like to use Automation Direct servo hardware because it is cheaper and just for a simple project. But I have a lot more experience with Schneider Modicon plc line.
One of my biggest glitches that I haven't fully understood yet, is what is the best way to communicate from the plc to the servo drive to tell it the next position? Is the best way with Modbus communication? Or a pulse output? I understand that servo motor must be paired with the servo drive, but I can use an independent plc, correct?
Hello everybody, I have tried to search on the google and in Somachine help, But I still haven't found any explanation how to start with servo...
3,084
Hi, I'm thinking about using commands for Melservo J5 controller via HMI without PLC. Have you guys done this kind of control configuration for...
139
Does any one know if its possible to jog a servo in control mode: torque mode(4). Im using the SSV to get a torque limit but when i do the change...
212
Hi everyone. I try to using FB MC_MoveAbsolute, but Fb was error [1103 A value out of the range is set as a commanded position or travel...
844
Hello automation experts, I'm trying to learn about servo axis control in AB ControlLogix PLCs (L33ERMS). Attached is an example of a servo...
1,075
