which terminals continuing shield in junction box
Hi all, which terminals are you using for continuing shields in junction boxes without earthing them?
Assuming you’re talking about analog wiring, why not just use the same terminals you are using for the other wires? Especially since you aren’t grounding the shields in the J-box. Just label them as “SH” or “G”.
This makes ordering easier, the bill of material consistent, etc.
They are installed in a control panel that was made in France and are intended for the termination of analog inputs. Each of the red capped...
450
6FX5002-2CD24-1GR0 Via Siemens Sinamics SINAMICS S120 are cuted. I got 1 project that they relocating old Machine to install to new location. Mut...
71
Does anyone have any recommendations for Electronic Circuit Breakers with 0V Terminals built-in and Fieldbus (IO-LINK, MODBUS TCP, EtherNet/IP?)...
212
I have a Beckhoff CX7000 IPC with some digital I/O built-in and I additionally need two analog inputs 0-10V. Can I install both Ethernet terminals...
245
With Wonderware, IFIX, FactoryTalk View, etc., it's very easy to have multiple HMIs, each with their own independent control, looking at the same...
542
