How can you determine the RPM of a 3 Phase motor without a nameplate ?
What is the application of the motor? It's likely you can determine the RPM of the motor from the application. For example, if the motor is on a positive displacement pump, it's probably a 4 pole motor (1750 RPM).
Hello, i am a beginner with a Siemens Logo 8 PLC. I would determine the direction of an object if it passes a whole cycle of 2 input sensors. See...
184
Hi all, Just looking through the CIP_AXIS_DRIVE data type in a Logix controller to look for something that can tell me whether the current...
1,070
I'm currently working on an MES interface PLC which passes around a whole bunch of strings. A lot of these strings are really just to allow for an...
1,118
I don't use AB much these days, and any installs I've done in years past have been setup by myself from scratch, so I've always known what...
2,082
Hello: I wonder if there is a way to find the CPU load of a Logix processor, and if it is not possible to determine this in an absolute way, I...
1,999
