PLC Simulator
tpal79
Feb 2013
Houston,Tx
How do I give a name for inputs, coils and registers on the simulator? I've tried every naming convention and just cannot get it.
Dear tpa179, please note the following post, which came in about six minutes before yours. Note especially the level of detail provided by the OP, which helps anyone reading the query to provide a solution.
Using RSLogix 5000 version 20.05 with a 1769-IF8 analog card set to 4ma-20ms which is set to engineering units with a 10hz filter. I am wondering if the is a way to grab a min/max value from the signal coming in?
Now look at your post:
Which simulator? Which PLC is being simulated? Which manufacturer? Which programming environment?
There are probably a dozen or more PLC manufacturers, with hundreds of PLCs simulated in various environments, plus there is the PLCs.net plcsimulator.net itself. Nobody can provide a useful answer to such a query without those data and possibly much more. I suggest reading this post before trying again:
http://www.plctalk.net/qanda/showpost.php?p=199757&postcount=1
One of the biggest mistakes we all continue to make is thinking that we, and our thoughts, are normative.
At least for AB 5K, I name all my variables IN_XXX, AIN_XXX, OUT_XXX and AOUT_XXX.
E.g. IN_[P&ID#]_[TYPE(e.g. LS,ZSC, ZSO, whatever)].
This makes for easy Excel replacement of variables between emulated program and real IO program. Also makes commissioning IO check much easier because you can focus on real IO by sorting on one of the four types.
This requires use of Aliases. Use Aliases. Tie your real IO to anything but an Alias and you put yourself into a pickle for AB simulator. Don't do that. Use Aliasing and IN, OUT, AIN, AOUT and you've pretty much covered 99% of IO you'll encounter. Network IO notwithstanding.
Showing a new guy basic programming and remembered the simulator here. But nothing happens when selecting the link. "Try our online PLC Simulator-...
25
1,620
hi everyone please give me a solution to timeout error in delta plc simulator,i have a doubt about firewall and antivirus we r using.
772
I just started to learn how to program PLCs. I was searching for the best simulator programs for learning how to code PLCs. The best one I could...
3,129
I am trying to find PLC simulation software that will connect with KepServerEx, in order to learn and test an OPC UA solution. My Siemens trial...
1,398
3,784
