ML 1100 High Speed Counter not counting in high speed
JonHopper
Feb 2010
Ontario
39
Hello everyone,
I am using a ML1100 and a 2048 pulse incremental two channel encoder.
I have set up the high speed counter and the ML1100 according to AB's specifications. The HSC:0/acc value does count up and down (depending on direction of the encoder shaft), however, the HSC begins to stop counting pulses after the shaft speed exceeds 90 deg / sec, roughly.
This is 512/s or 500Hz input signal. Why does the HSC, which is supposed to be 20KHz input frequency max, not read an input signal of such low frequency?
I have tried going offline / online to modify the IO settings (input filter frequency) but I am unable to change the input filter frequency regardless of whether I am offline or online.
Can anyone give me any tips? I'm stumped.
Thanks,
Jon
Does the 1100 only have 1 high speed counter, but it can have multiple inputs? And so then the 1400 has 6 HSC and you have a choice of multiple...
1,716
Cannot drag HSC function into the rung on the Micrologix 1100 series B.
1,524
Hai everybody, I have a small issue of adding delay in the pulse count of the high speed counter input of the micrologix 1100.The pulse comming...
4,416
Hi Everybody.I have little bit experience in HSC in micrologix.I have high speed pulses input from weightometer given to HSC of micrologix.My...
19
9,470
Hi all I have to set up a shaft encoder to a high speed input on a micro logix 1100.I have used the high speed input card in control logix and I...
10,977
