Siemens Logo
JulianBell
Nov 2013
Cape Town
HI
Very new to Siemens Logo programming and have a 24H deadline.
How do I set it up so that I can adjust the timer settings directly from the arrow keys on the logo unit and not have to plug in my laptop every time?
TIA!
You can always set time using display...go to the Parameters on display and find Your timer there.....(timer must not be protected).......
Thank you so much guys. Got my programme working, just going to change the time from the main screen.
One more thing I'm struggling with, getting connected to the Logo via ethernet.
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
287
Hi Lads, I want to implement a flood prevention system with my domestic water pump. The intention is to have the water pump cut off on a daily...
1,077
We need a Really Simple and Cheap controller that has a display or a Web Interface where we can change some set points. We were thinking about a...
1,040
hello i have LOGO! 12/24RCE and i am looking for a schematics of electronic board. Or if someone know what is the burned component on the photo.
1,408
Hi, I'm no expert in PID regulating so I need some advise. I have a VFD controlled deepwaterpump that is maintaining the pressure in a closed...
24
11,905
