Siemens LOGO
theColonel26
Feb 2014
West Michigan
785
We need a Really Simple and Cheap controller that has a display or a Web Interface where we can change some set points.
We were thinking about a Siemens LOGO. Do you have to buy the programming software for them? if so How much is it?
I would prefer a Click PLC and a C-More Mini HMI but that is $300 total. And kinda overkill, so the Siemens is the best thing we have found so far.
I've installed several of the identical IDEC version (FL1F) that they refer to as a "SmartRelay". The software was a free download and they've operated flawlessly for about five years. They seem feature rich for that price point but programming by the front buttons is a frustrating waste of time. I'm an old ladder logic guy but I had no experience with function block programming at the time so there was a steep learning curve initially for me. Ethernet access with a built in browser is simple + no interfacing hardware is necessary for hardwire connection. I like them
According to me SIEMENS LOGO is fine for smaller project like, for example, an irrigation system or light control. Of course it can be used for a more complex projects as long as you are within the block limitation of the LOGO.
It also has a MODBUS TCP Master/Slave functionality which is a good way for communication with other devices.
The webserver programming environment is called Logo Web Editor(LWE) and you need an SD Card to establish a web server on the LOGO.
One of the limitation are the outputs, if you need more you have to buy an extension module that will add to the initial costs and the extension module are not that cheap.
As far as I know the programming environment has a paid license that is perpetual.
Best Regards
Konstantin Kolev
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
287
Hi Lads, I want to implement a flood prevention system with my domestic water pump. The intention is to have the water pump cut off on a daily...
1,077
hello i have LOGO! 12/24RCE and i am looking for a schematics of electronic board. Or if someone know what is the burned component on the photo.
1,409
Hi, I'm no expert in PID regulating so I need some advise. I have a VFD controlled deepwaterpump that is maintaining the pressure in a closed...
24
11,908
Hi there, I have three pumps, I have to start first pump for 8 minute and after that it should be turned off and other one start simultaneously...
1,853
