Panelview 600
dhuber
Jul 2009
Ontario
49
I have a SLC 5/03 connected to a Panelview 600, what just happened was the power supply on the PLC was shorted out through the someone plugging in a ethernet cable direct in the back of the panelview to an ethernet port on a computer. I downloaded everything back to the PLC and communications works fine between the PLC and the Panelview, but if i go to plug in my ethernet cable, through my UIC box, it pops up on the panel view with required nodes not found, or no nodes on network. When i then unplug the ethernet cable from the back of the panelview, the message goes away and everything runs fine again.
I can see the panelview in rslinx, but not the PLC, i can upload and such from the panelview, i am just wondering if that port on the panelview is fried and will always do that, or if there is something i can change in the communication settings. The communication settings are the same, and i was able to see both at one point connecting through the back of the panelview.
This is just more of a convenience thing than anything.
Thanks.
I am trying to go to a 504 CPU. and on my hmi I am getting a 9028 error. can someone explain what they mean by change reference?
249
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
504
Hello, Friends Please someone help me find right cable to communicate Panelview 600 (2711-B6C9) to Micrologix 1200 (1762-L24AWAR). AND any advice.
316
Hello , I have an HMI of PV+ 600 (2711-T6M5D) Ser A Rev B, This HMI doesn't have the ethernet port i have to take backup through communicate...
684
Hello all, I copied the MER file from one PanelView Plus 600 to another one, using a USB drive. On the new HMI, I copied the MER file to the...
663
