Dont allow datatransfer from MicroLogix PLC to Memory module
Holmslykke
Mar 2019
Randers
Hi Guys,
Can anyone tell me if it is posible to
explain to me whether it is possible to set a Micro1400 Allen Bradley PLC to not allow data transfer from a MicroLogix 1400 PLC to the data module?
If it is possible please tell me how it is done. the software used to program the PLC is Logix 500, and the memory module used is 1766-MM1
There is no way to block a new program being written to the EEPROM if the person has the software and has access (no password) and knows the procedure. If the memory module were a PROM vs. an EEPROM the PROM is a single write.
Password protecting the controller would prevent this but would also prevent the customer from viewing the program.
I can't say for certain as I have never tried to limit this specific function but you may be able to do it by setting up factorytalk security as it gives much more granular control over the entire feature set. If you have the capability you could set it up in a VM and test it.
In the past, many people would use the 1747-PSD to move the same program to many units which would solve the issue of the thread referenced in the post above. The 1747-PSD works with the SLC 5/03, 5/04, 5/05, Micrologix 1000, 1100, 1200, and 1500 and I think it was discontinued before the 1400 was released but I imagine it may still work.
These are still available but they are pricey. https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=1747-psd&_sacat=0
https://literature.rockwellautomation.com/idc/groups/literature/documents/in/1747-in001_-en-p.pdf
Hi; First of all, I am sorry that my post is not relevant with this forum. I have recently purchased Samsung cell phone. I have alreay saved...
87
Hi I am in the process of making an OT lab for training and to test incident response, an i keep hearing NOT to scan network because some...
916
A MELSOFT application error has occurred. Please restart. <ES:020000006> Why Occur this message? I'm try connecting to USB Pls Help me..:shock:
2,047
I have a Delta DVP 16EC PLC and does not have a RUN-STOP button I can make it go into RUN with the PC in the simulation and everything is perfect...
2,039
Hello, I'm running my Plc in PLC Simulator (Unity Pro XL). Intouch sees the connected links but the tags are not matching (+1 on InTouch)...
1,256
