FactoryTalk View SE - Antialiasing?
Yes, it is painful. Don't even get me started. I've used here and there over 20 years and the object handles getting out of sync is still a flipping thing. I thought ClearSCADA was bad.
I hate to keep starting all these threads but like why are imported PNG files all messed up? And...
I've seen PNG issues when I edit them with 3rd party software or online editors. The image preview will be messed up. It can also cause crashing and hangs. You would think their software would have better error checking.
It makes no sense. “We support PNG now!” No you don’t. Why is it an option to import PNGs and BMPS and so on if PNGs are all jacked up. They look fine in windows and oh (just found this out) they look ok if you add them under “Images” first and then use an image object. WTF?
Another cool thing is that you cannot change the object one pixel nudge with arrow keys and must hold the shift key. Most every other object based graphics program I’ve used lets you adjust it or use a shift and or alt key to move object 10-25-50 pixels. Like Control+D and then arrow over and up and you’ve got a new object all lined up. Nope!
And now over the last few days it’s been randomly changing from a single pixel nudge to something like 16 pixels. I have to restart the program to get it to stop.
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
106
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
130
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
176
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
121
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
200
