Problem with Allen Bradley MMI Panel View PV 400
neerajpuranik
Feb 2006
Bharuch, Gujarat
87
I have a machine supplied with Allen Bradley PLC ( Micrologix 1200 ) & MMI PV 400. This MMI has numeric keypad to enter numeric values. We are commissioning the machine. It has been observed that half of the numeric keypad is working & other half is not working i.e. Keys 0,2,3,6,9 are working properly while Keys 1,4,5,7,8 are not working at all.
When we open the MMI screen there are two connectors. I checked them for any loose contact but they seems intact.
Has anyone ever come across such problem or suggest anything to me.
Regards,
Replace the whole PanelView unit or send it out for repair. It's obviously defective. To prove it, swap it with a "known good" unit and see if the problem still exists. (I doubt it will.)
GOOD NEWS: It may still be under warranty.
My guess is that the PanelView has a bad internal connection for certain rows or columns of membrane switches. But if you take it apart yourself, you will probably void the warranty.
I have 1769-IF4 module and 1766 micrologix 1400 series B controller, when connecting Analogue input in module it's showing maximum values of...
1,688
We have an application with an Allen Bradley servo driving a rotary table. During normal operation the servo positions perfectly (within 0.001...
2,281
Hello everyone, I face a problem with setting connection between my computer and PLC using NAT addressing. I configured NAT. In private network...
1,996
Hello, I have a drive allen bradley powerflex70 that works normal it shows that it has start and frequency variation but there is no output 0...
2,111
Above mentioned HMI is installed in my plant with Micrologix PLC. Yesterday the HMI suddenly stopped working during plant operation and HMI's...
4,929
