Ab kinetix 300 i/o expansion block required USER MANUAL INCORRECT??
Skolnik
Aug 2015
Chicago
Hi folks, I've been having a problem enabling my Kinetix 300 over E/IP. 1stime Kinetix/EIP user here. A few questions Im hoping to find aswers too.. Any help is appreciated
Project Components:
Servo Drive ------- Kinetix300 E/IP
PLC ---------------- Micro850
Software ----------- Connected Components Workbench
I've connected to the drive over E/IP; have modified parameters in motionview, checkphasing runs fine; Digital IO>enable... (all from the manual)
...and the drive will not enable. Shunt in not wired; is this required?
So I found one thread and one written document stating that the i/o expansion block IS required in order to use EIP communication?
Link 1 http://cednebtrc.com/ftp_bbernier/K300 Minimum Wiring needs.pdf
Link 2
http://www.plctalk.net/qanda/showthread.php?t=87477
Any Advice on how create the worlds simplest program in CCW in order to write messages in to the Drive using EIP.
Thanks!
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
179
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
169
Hello PLCS.Net Forum, First time posting. Let's assume I am a novice. BASIC PROBLEM: My servo/linear piston is no longer zeroed to the...
265
Hello. I have a few machines that use Kinetix 300 (each machine has two drives). Both drives on one of the machine keep losing IP address. They...
117
Hello, We have had a machine running for the last 10 years. It has 2 x Kinetix 300 drives. Around a year ago, one of the drives failed. We were...
471
